11-06-2023, 08:02 AM
				Another Hard Starting Question
			Hello,.I trust that  20 PSI  of cranking fuel pressure 0n a 02' boxster 2.7 is NOT enough to start it,..I researched the form and I found where it's suppose to be 3.3 Bar,..which i think is to equal 30-35 PSI,it was hard to start 2-3 times last week./and now will not start at all, but really tries to,It sputters and pop's a lot then it just crank's, Thank's ,for the help...Frank
			11-06-2023, 08:16 AM
			You have a fuel pressure issue.
				“Anything really new is invented only in one’s youth.  Later, one becomes more experienced, more famous – and more stupid.”  - Albert Einstein
			11-06-2023, 09:16 AM
PSI times 14.504  equals bar...... so 3.3 bar would be 47.86 psi
			11-08-2023, 07:13 AM
			Thanks for the Info Gentlemen, fuel pump on the way..!  Frank
			11-08-2023, 01:35 PM
			Doesn't these cars have a fuel pressure regulator? Just curious..
			11-08-2023, 01:37 PM
Early cars did, it was on the fuel rail, later models, it is in the fuel tank.
			11-08-2023, 06:21 PM
 Thanks JFP!
			11-23-2023, 12:53 PM
			Installed fuel pump,Great pressure now..but still a no start..so crank sensor next after that...who know's , hopefully crank sensor is it  !  Happy Thanksgiving !!
			11-24-2023, 05:16 PM
			Installed crank sensor..back to cruising
