Old 09-12-2022, 11:03 AM   #1
My slow refueling adventure
I'm having the all-too-common problem of the tank not filling to the top. Constant clicking off of the pump nozzle. Filling the tank with the fuel handle at every angle of 360 degrees didn't work. Pushing the little tab that's normally depressed by the cap didn't work (although the tab is looking kinda worn). This has been going on for a few years, and I'd talked myself into thinking this is just a Porsche thing, but now I want it fixed. It did work, so there's something wrong. No CEL/MIL. No difficulty starting after filling.
After a ton of research, it finally sunk into my pea brain that there are two systems: the main Evaporative Emission Control System (EVAP) that captures stray fuel vapors while operating and sitting, and the intermingled Onboard Refueling Vapor Recovery system (ORVR). It's the ORVR that vents the tank during fueling.
Pushing the fueling nozzle into the filler hole moves a flap that activates a reed switch on the filler pipe. This switches operation from EVAP to ORVR, activating two valves:
- the ORVR valve on top of the fuel tank
- the "fresh air" valve located in the front right wheel arch
With those two valves open the tank can vent to atmosphere during fueling, through the carbon canister.
So why is mine not working?
Some people have a problem with Fuse E6, which powers the ORVR system (grounds out from a telephone connector in the center console). Mine is fine. So next is the two valves. I pulled off the wheel liner to get to the valve in the wheel arch. I can hear and feel it activating. Then I pulled out the battery and the lid under it, getting to the fuel tank. The ORVR valve there I could also feel activating.
Assuming the valves are actually doing something, that leaves the carbon canister and the interconnecting hoses/pipes. The atmospheric line from the fuel cap area seems like a potential culprit and it's subject to collecting debris. My question: how is the line disconnected from the valve plenum without damaging it?
Assuming the lines aren't plugged, and the carbon canister is plugged, wouln't this set off a CEL/MIL? It is part of the EVAP system as well.
Then there are a couple of potential mechanical issues not related to ORVR air flow. The spitback valve at the end of the filler tube could be sticking or blocked. But woudn't the tank be difficult to fill in its entirety, rather than just near the top? Then there is the issue with the flexible fuel hoses inside tank obstructing the spitback valve. Porsche issued a TSB: Fuel Tank Hose Modification 5/99 2015 - tie fuel tank hoses out of the way of filler pipe flap. I couldn't find the TSB. Is it applicable to cars past 1999? Does it make sense that like in my case it started about 15 years after the car hit the road? Can this be determined by putting a scope down the filler pipe or would the spitback valve get in the way? I did try this but got chicken and stopped when the scope got to a section of the pipe that looked corrugated.
So my questions, for those of you kind enough to help:
1. How is the pipeline disconnected from the valve plenum without damaging it?
2. Wouldn't a plugged carbon canister set off a CEL/MIL?
3. Does anyone have the TSB? What years is it applicable to? Can this happen many years after the car is sold?
4. Have I missed anything as far as potential failure mechanisms or is there any other advice?
Thanks!
Old 06-19-2023, 03:08 PM   #2
Slow fueling
For those of you that have tried everything you’ve read about on how to resolve the mysterious slow fueling/splash back issue, read this post. I’ve been chasing this issue for years and although there is plenty of great advice out there on this, (relays, valves, fuses, filler neck vent, gas cap, carbon canister, etc.) none of it worked for me. I had gotten used to taking my sweet time fueling the car and assumed this would be the normal operation forever. Over the past few weeks my fuel gauge became erratic and unreliable, so I decided to replace the sending unit, fuel pump and filter as a kit since all these components are twenty-two years old on my car. During the replacement process we discovered the filler neck extension laying loose at the bottom of the fuel tank. This is a rather large piece and I suspect it may have been the reason for the erratic gauge as it may have been interfering with its mechanical operation. We reattached the extension and secured it with tie wraps to ensure it would stay put. The first trip to the gas station was a full flow fill to the top for the first time in four years.
2001 Boxster S
930turbo is offline   Reply With Quote
Old 10-02-2023, 01:41 PM   #3
To close the loop on this one, the problem is fixed. One of the local indies thought it was the valve at the top of the filler tube, but discovered that that wasn't it. He then tried a number of things to diagnosis, but the only thing he could find was that the evap canister "seemed heavy". So he disconnected it and gave the car back and told me to try filling it (I needed the car back). So I did and it did in fact fill full. So the canister was replaced and it's all good.
