Old 08-07-2023, 04:45 PM   #1
Help needed, we can`t find oil cooler orings for the boxter 2.5
Hello, we fixing a 2.5 boxter it has an oil cooler leak, so far we tried all available rings
P999-707-409-40
P999-707-389-40
P999-707-344-40
P999-707-193-40
which doesn`t fit. So we are guessing maybe it`s an early production model and orings were changed for the follow-up models. Here is a VIN number WP0CA2982VS621430, we hope that someone could help us to find the right part.
Thanks,
Elai
Coltkiss.45 is offline   Reply With Quote
Old 08-07-2023, 06:53 PM   #2
78F350's Avatar
Your VIN identifies it as a 1997 model. They do have a different style oil cooler.
Are you installing an oil cooler for a 1997? Be sure to specify the model year when you search.
That's the only year with that style.
If you are installing a later model oil cooler on your '97 you need an adapter plate like this:
Oil Cooler Adapter for '97
This is the adapter to put a later model or S model oil cooler on a 1997 engine. List price is now about $190 new.
Associated Part Numbers: 996 107 129 00, 996-107-129-00, 996-107-129-00-OEM, 996.107.129.00, 99610712900
"Porsche Heat Exchanger Mount Plate"
'Gently used' and fully functional. Comes with 4 New o-rings to install the adapter.
Your new oil cooler will need 4 more o-rings. Pretty sure the part numbers are 99970740940 (26 x 3mm) & 99970738940 (35 x 4mm), but I am occasionally wrong.
$75 shipped. USA addresses only.
Old 08-08-2023, 06:02 AM   #3
Yes it is 97 and we are not changing oil cooler, we just trying to fix the oil leak. So seems looks like the one we have on the car has different orings and no one can figure out where to get those.
As of now, it looks like we might need to install a later oil cooler with that adapter plate.
Old 08-09-2023, 06:56 AM   #4
78F350's Avatar
I did a search at dealers specifically for a '97 and came up with the same part numbers that you already listed.
The Parts Catalog shows only those o-rings too.
Can you post a pic of your oil cooler, where it mounts and the o-rings? I'm curious to see exactly what the problem is.
Old 08-12-2023, 09:07 PM   #5
The car pissed off us and in storage but i will do pictures next week, thanks for the reply.
Old 08-24-2023, 12:51 PM   #6
Hello, may i ask where the bleeder hose on the top of the updated cooler goes to? the one we have is just flat.
Old 08-24-2023, 01:32 PM   #7
It goes to the plastic coolant surge tank in the trunk. The oil cooler is the highest part of the cooling system on the engine, so it is where any air bubbles would collect, the hose bleeds them off into the tank.
Old 08-24-2023, 05:41 PM   #8
78F350's Avatar
The '97 engines bled air from a tube on the oil pump housing. The hose on top of the oil cooler replaced that on later models. This thread discusses how to deal with that: '97 motor in '98 car -- oil pump plug
I think the best solution is the plug that trygve found. Part #99610711900
