Old 04-23-2013, 08:35 PM   #1
The Radium King's Avatar
electric power steering project
slowly putting the gear together:
- Vauxhall astra/zafira electric PS pump c/w mounting bracket ($200; used on ebay uk):
Vauxhall Astra MK5 H 2004 2010 1 3L Diesel Cdti Electric Power Steering Pump | eBay
- two GSR PS rack to 6AN male fittings ($110; to convert PS rack to AN fittings):
GSR Power Steering Rack Fittings - 6AN - Porsche 986, 987 Boxster, 996, 997 911
- Pending: Russell 16mmx1.5 o-ring seal to 6AN male fitting ($8; to convert electric PS pump pressure side to AN fitting):
Russell 648060 Russell Power Steering Adapter Fittings
- Pending: two 6AN female/female hoses ($?; depending on length).
notes:
- PS pump bracket can be easily bent to mount on flat surface, and comes with three rubber vibration isolation mounts between pump and bracket
- if mounted on upper tray of front trunk will clear hood (mounting on upper tray will also give good access to battery and keep main trunk free for helmets)
- original PS pump can be gutted to serve as dummy pulley if you have deleted AC (thanks eric) otherwise all required is a shorter belt; suncoast and bgb also sell AC delete pulleys (marketed for the 987.2, but will fit the 986 as the AC compressor part number hasn’t changed)
- PS pump wiring is as follows:
red - battery +12V
brown - ground
black - ignition +12V (i.e., only runs when key is on)
blue/white - alternator dash light (to turn it off if the key is on but car not running)
brown/white - not required (for diagnostics)
need to confirm:
- 6AN hose will fit over reservoir return spigot (presume not a big deal)
- source for Bosch 4P weatherproof male electrical connector to connect to PS pump electrical connector (for clean install, otherwise i can splice the wires)
- that i got the proper Russell fitting (presume metric, but could be 5/8”)
- hose length and routing from PS rack to proposed mounting location
- appropriate grommets to give bulkhead penetrations a finished look (got a box of them; something should work)
- source for switched +12v and alternator wires (under the dash somewhere; just need some time with the wiring schematic to get a colour code)
almost there; cost will be around $400 all in.
