Old 05-22-2023, 02:56 PM   #5
Registered Member
Originally Posted by robedywer View Post
Hi
Got flat battery and cant open front bonet to charge battery . Try to find emergency cable on front wheels both side but is not here . Try. with jump cable in fuse box but won't open front or real trunk , only made clicking noise in fuse box location . The remote key also not working . Try to power the car by cigarette got power to dashboard all sem to work (horn, wipers etc) but cant open bonnet by switch also the door lock buton on dash not working .
Can any one help me to open the bonnet and charge the battery ?
I have found that connecting to the terminal in the fuze box needs to be done with a decent sized battery, as it takes a fair amount of current to run the actuator. A battery charger wouldn’t cut it, but it was able to connect to my motorcycle battery (and my MC jumper cables have small clamps on the ends, which helps) and that worked just fine.
Tom Coradeschi
03 Boxster
tcoradeschi is online now   Reply With Quote
