Old 11-19-2006, 06:10 PM   #1
Franco's Avatar
Airbag light came on
Hi guys, did anybody have the air bag light go on and know what the problem is or how to make it turn off.
Any info on this problem would be appreciated. Thanks
Franco is offline   Reply With Quote
Old 11-19-2006, 06:17 PM   #2
it is probably one of your seatbelt receptacles. It's common for the filament inside them to go out and set off an airbag light.
Replacing them isn't expensive if you do it yourself. Disconnect battery, wait five minutes. Remove four bolts on the seat, unlatch the wiring harness, and remove and replace the receptacle.
Happens all the time on Boxsters and 996's. Crappy manufacturing.
Old 11-19-2006, 06:27 PM   #3
Franco's Avatar
Thanks, does the light turn off if i disconnect the wiring harness or must i replace the receptacles on both seats first for it to turn off, just wondering.
Old 11-20-2006, 12:18 PM   #4
Ray
I believe you will need the fault light turned off by a) yourself; need Porsche code reader/setter http://www.durametric.com/buy.php OR b) Pay your dealer a couple hundred clams. I have not witnessed a light to go off by itself (yet).
Ray is offline   Reply With Quote
Old 11-20-2006, 12:40 PM   #5
Can't resist...
Back your car away from what you just hit and have a tow truck take the car to the dealer for repairs.
Sammy is offline   Reply With Quote
Old 11-20-2006, 02:09 PM   #6
Franco's Avatar
Originally Posted by Sammy
Can't resist...
Hi Sam u must be a genius why didn't i think of that!
Old 11-20-2006, 02:11 PM   #7
Franco's Avatar
Oops Couldn't Resist
Old 11-21-2006, 07:30 AM   #8
Well... I don't like to brag but I did win an award for some coloring I did in Kindergarten...
Old 11-23-2006, 05:57 AM   #9
second the durametric for reseting the lite and what codes were stored.
rpmgroup is offline   Reply With Quote
Old 11-23-2006, 07:12 AM   #10
And you slept at a holiday inn last night too!
Old 11-23-2006, 08:02 AM   #11
boggtown
Posts: n/a
All I know is that if you DONT have an airbag light on, and you you disconnect the seat harness, thats nish nish, as long as you never put the key into the ignition everything will be auk ya. (sorry, had to throw some borat in)
