Old 11-19-2006, 06:17 PM   #2
RandallNeighbour
it is probably one of your seatbelt receptacles. It's common for the filament inside them to go out and set off an airbag light.
Replacing them isn't expensive if you do it yourself. Disconnect battery, wait five minutes. Remove four bolts on the seat, unlatch the wiring harness, and remove and replace the receptacle.
Happens all the time on Boxsters and 996's. Crappy manufacturing.
