Old 10-27-2022, 09:45 PM   #1
EB_KC's Avatar
Timing Chain Guide Advise
While I have things opened up I am staring at the timing chain tensioner guides. They have a bit of wear. The flat guides have a groove with a max depth measured at .004". The tensioner guides have a groove with a max depth measured at .041". The wear is mostly at the end where it looks like the chain deflects the most. Should I replace these, or is this acceptable wear? Motor has 118k miles.
Looks like I would need to remove the oil pump housing to extract the bolts that hold the guides on the front of the motor.
EB_KC is offline   Reply With Quote
Old 10-28-2022, 06:21 AM   #2
since you're that far in, I would absolutely replace them.
Old 10-28-2022, 06:26 AM   #3
When you remove the oil pump, replace the cast pump drive shaft with LN Engineering's chrome moly steel upgrade. Cheap insurance.
Old 10-28-2022, 11:03 AM   #4
EB_KC's Avatar
Parts on order. Thanks for the replies.
