Old 10-27-2022, 08:45 PM   #1
EB_KC
EB_KC's Avatar
Timing Chain Guide Advise
While I have things opened up I am staring at the timing chain tensioner guides. They have a bit of wear. The flat guides have a groove with a max depth measured at .004". The tensioner guides have a groove with a max depth measured at .041". The wear is mostly at the end where it looks like the chain deflects the most. Should I replace these, or is this acceptable wear? Motor has 118k miles.
Looks like I would need to remove the oil pump housing to extract the bolts that hold the guides on the front of the motor.
EB_KC is offline   Reply With Quote
