Old 07-16-2022, 12:03 PM   #1
Intermittent stalling when hot / after re-fuel
I just had a long track day, alltogether the car ran for approx 200 minutes, basically flat out :-)
After about 2/3 of the day I had to re-fuel, after this the engine sometimes just shut off for 1-2-3 seconds at a time. Totally shut off, nut just hesitated or lost ignition on a separate cyl.
I wonder if this somehow could point to a bad crank shaft position sensor? I have actually had the exact same issue at a previous tack day, also the the car was really hot, I had just re-fueled when it started.
After some cooling down I could drive home without no issues at all.
986S 2003, all ideas are very appreciated!
Old 07-21-2022, 10:11 AM   #2
So today at the hottest day at the year 33 degree celcius it started stalling again. I'll order a sensor and see if it solves this issue.
Old 07-21-2022, 12:43 PM   #3
Let us know if a new crank sensor solves the problem.
If it does not then an issue with the "EVAP" system may be the problem.
Things like a faulty purge valve stuck open can cause hard starting after a refuel and stalling.
Old 07-22-2022, 05:24 AM   #4
Thanks, I´ll report back!
No real problem starting, just intermittent when driving. Did change the purge vave 2y ago so it should be ok.
Old 08-06-2022, 04:18 AM   #5
So, I changed the sensor, car runs fine... We´ll see if the issue is solved, I guess so.
Was a bit tricky to reach the sensor at first until I found a good angle with my arm. The tricky part was really to release the connector, I first got it free from the fastener, then used a flat screw driver to "unclick" the connector from below.
Old 08-11-2022, 12:47 PM   #6
bcrdukes's Avatar
Robert, thanks for the update.
I'm curious whether or not you had a hard time starting the car when this happened?
2001 Porsche Boxster S
bcrdukes is online now   Reply With Quote
Old 08-11-2022, 02:13 PM   #7
No, just sudden "blackouts" while driving. So far the car runs fine after the change of sensor...
Old 08-12-2022, 07:17 AM   #8
bcrdukes's Avatar
Ah, interesting.
On the odd occasion (mostly hot days) upon starting the car, it will try to start for a good 5 - 7 seconds before firing up and my heart just stops. It doesn't happen often so I'm not sure what causes it.
Old 08-12-2022, 08:13 AM   #9
Ah, interesting.
Classic CPS problem, only happens on "hot start". Look up DTC codes 0335 and 0336 for how to diagnostics to test the sensor.
