Old 06-21-2022, 10:18 AM   #1
jaykay's Avatar
door membrane sealant
Is there a correct door membrane sealant to use when reassembling door internals? Looks like it could be some white, Wurth product..
It would be a shame to go through all the work and have it leak after.
986 00S
Old 06-21-2022, 11:53 AM   #2
It is a simple sealing mastic, and can actually be found as a tape that can be cut and applied.
Old 06-21-2022, 12:12 PM   #3
jaykay's Avatar
Okay thanks is it best to search under sealing mastic to find something suitable is there a brand name that you can think of...
986 00S
Old 06-21-2022, 12:52 PM   #4
We use 3M brand sealants and mastic, but there are other quality alternatives.
Old 06-22-2022, 08:20 AM   #5
000 043 101 00 Rubber Seal Strip
SlowernOlder is offline   Reply With Quote
Old 06-22-2022, 08:41 PM   #6
jaykay's Avatar
Thanks for the seal specs gents. Just thinking as I heat up this old sealant and membrane: will these new sealants allow me to go back into the door in the future…. not that I ever want to. The new sealant may mean ripping things apart to get back in….
986 00S
Old 06-25-2022, 03:57 PM   #7
I’ve used acoustic sealant used in home construction. Can be found in the caulking section of Home Depot etc. it stays sticky and pliable.
CdnRD is offline   Reply With Quote
Old 07-01-2022, 01:47 PM   #8
jaykay's Avatar
Thank you sir I am right into the door now do this is helpful
986 00S
