-   -   door membrane sealant (http://986forum.com/forums/performance-technical-chat/82350-door-membrane-sealant.html)
jaykay 06-21-2022 10:18 AM
Is there a correct door membrane sealant to use when reassembling door internals? Looks like it could be some white, Wurth product..
It would be a shame to go through all the work and have it leak after.
JFP in PA 06-21-2022 11:53 AM
It is a simple sealing mastic, and can actually be found as a tape that can be cut and applied.
jaykay 06-21-2022 12:12 PM
Okay thanks is it best to search under sealing mastic to find something suitable is there a brand name that you can think of...
JFP in PA 06-21-2022 12:52 PM
We use 3M brand sealants and mastic, but there are other quality alternatives.
SlowernOlder 06-22-2022 08:20 AM
000 043 101 00 Rubber Seal Strip
jaykay 06-22-2022 08:41 PM
Thanks for the seal specs gents. Just thinking as I heat up this old sealant and membrane: will these new sealants allow me to go back into the door in the future…. not that I ever want to. The new sealant may mean ripping things apart to get back in….
CdnRD 06-25-2022 03:57 PM
I’ve used acoustic sealant used in home construction. Can be found in the caulking section of Home Depot etc. it stays sticky and pliable.
jaykay 07-01-2022 01:47 PM
Thank you sir I am right into the door now do this is helpful
