Old 04-18-2022, 11:44 AM   #1
bcrdukes's Avatar
Oil Drain Plug - Proper Tool Size
Hi Folks,
I am curious what is the proper tool or size required for the factory oil drain plug? I've read that it's 8mm but I either don't have the right tool or I am missing something altogether. I want to ensure I have the correct tool for future oil changes at home. Thanks!
2001 Porsche Boxster S
bcrdukes is offline   Reply With Quote
Old 04-18-2022, 01:07 PM   #2
There all 8mm
2022 PCA Zone 7 Autocross Chair
2001 Boxster 986 (base) #414
-PCA GGR: Class Champion AX12 '18, '19, '20; CC06 '21; CC05 '22; PAX 5th '19, 3rd '20, '21, & '22
-PCA Zone 7: Class Champion P14 '18, '19; P02 '20; P-03 '22; PAX Champion '20 & '21
BrantyB is offline   Reply With Quote
Old 04-18-2022, 01:33 PM   #3
steved0x's Avatar
Both of mine have the LNEngineering magnetic drain plug, so I don't have an OEM plug to verify, but a set like this will have what you need:
3/8 In. Drive Metric Hex Socket Set, 6 Pc.
https://www.harborfreight.com/38-in-drive-metric-hex-socket-set-6-pc-69546.html?_br_psugg_q=hex+socket+set
Old 04-18-2022, 02:47 PM   #4
bcrdukes's Avatar
Originally Posted by BrantyB View Post
There all 8mm
I can confirm that an 8mm hex does not fit this. Too small. I know that a 5/16 hex "works" but it's not a perfect fit and has a chance to strip the edges if not fully inserted and this is where I learned my mistake.
Old 04-21-2022, 04:07 PM   #5
You ever get this figured out?
I agree with the others—8 mm is right. That's what I've always used.
And you say 8 mm is too small, but 5/16" works. But that doesn't make sense: 5/16" is SMALLER than 8 mm. Or when you say "too small" are you talking about the drain plug opening?
Old 04-21-2022, 10:44 PM   #6
bcrdukes's Avatar
Unfortunately, no. But is the correct tool an M8 triple square bit?
https://www.pelicanparts.com/More_Info/GRY1108S.htm?pn=TOL-GRY-1108S&bt=Y&fs=0&SVSVSI=1048
Old 04-22-2022, 04:05 AM   #7
No, you want a plain ol' hexagonal Allen wrench, 8 mm.
Old 04-22-2022, 10:00 AM   #8
FWIW the oil plug in your picture looks odd. it only has very small indentations for a hex. I'm pretty confident that is not OEM or even a common aftermarket.
Here's one of the several drain plugs I have and all have more defined hex openings than the one you show.
Old 04-22-2022, 10:02 AM   #9
Or its already stripped. Hard to tell from pic
Old 04-22-2022, 11:01 AM   #10
Seen this a thousand times, it is the factory plug after some moron repeatedly used the wrong size tool to undo it. Throw it away and get a new plug, and the correct tool.
Old 04-22-2022, 07:31 PM   #11
bcrdukes's Avatar
Sorry folks, I should have mentioned this in my original post but the oil drain plug I posted in my photo was literally purchased from the dealership and I took the photo at the dealership. Unless the dealership is scamming me (it is a corporate owned store) then I need to find a new dealership to buy parts from.
Old 04-22-2022, 07:40 PM   #12
That looks to me like a torx socket, maybe a t40?
Porsche does dumb **************** with some of these plugs, like the triple square"anti theft" 5 speed transmission plug.
Id love to know the story behind this. A Porsche exec's mistress' husband finds out about the affair, and to seek revenge the husband uses an 8mm Alan key to drain the guys oil in the middle of the night, destroying the engine when the cheating bastard tried to go to work the next morning. He cabs it to work and the first order of business is to change all oil plug specs!
Sorry, it's late, I found that amusing...
