Old 12-27-2021, 05:10 AM   #1
Rennzenn
j.fro's Avatar
fuel injector issue
So I’ve got obd2 code 1241, fuel injector, cylinder 5, open circuit. I get the FI #5 part. What’s “open circuit “ ??? Is it the FI or the wiring? If I swap in another injector, problem solved??
Rennzenn
Jfro@rennzenn.com
Old 12-27-2021, 06:59 AM   #2
Wiring issue, the injectors themselves rarely fail electrically. Correct diagnostic would be to check the questionable injectors electrical pulse width against those working normally.
Old 12-27-2021, 09:09 AM   #3
The Radium King's Avatar
#5 wiring is subject to mechanical wear where the injector connector plugs into the injector; have a look there for damage.
Old 01-02-2022, 04:38 PM   #4
Rennzenn
j.fro's Avatar
Thanks for the replies. I fiddled around with the #5 connection over and over, no change. Then I hooked up the durametric and stopped each injector individually.... Turns out #3 was disconnected. God only knows why the code was for #5.
FYI 2000 3.4 in a 2000 986
Rennzenn
Jfro@rennzenn.com
