Old 09-17-2021, 02:34 PM   #11
From what I see in your picture in post #15 and what your describing here. (valves broken off). There was a mechanical issue. Broken wrist pin, broken rod, valve spring or lifter issue. will be interesting to see what you find with further disassembly.
I think you are onto the mark with the valve spring. One thing I did not mention is the car ran, but poorly, after it lost all power during a run. I started it maybe five or six times with no power and no expensive engine noise. But the last time I started it, it made all kinds of expensive engine noise.
So, if the valve spring failed partially maybe the valve would not hit the piston but if it later failed completely then it would and that would cause the damage chain to start.
Headed out to the garage in a few minutes will know more tonight hopefully.
Silber
2002 Boxster S - Silver/Boxster Red
Coilovers - LSD - CAI - High Flow exh. - F&R Adjustable Sways
LN 3.2 to 3.8 - parts acquired, pending assembly and tuning
Silber is offline   Reply With Quote
