Old 10-25-2006, 04:45 PM   #1
Rubber Under-Engine Scoops
One of the little rubber scoops on the belly of the car right behind the crankcase came undone and was dragging on the ground. It's come partially off before, and I guess sliding back on isn't enough to keep it on. Does anyone know 1- what this part is called for replacement (it got torn up a bit) and 2- what might be a good way to adhere it to the metal frame its attached to? Was thinking epoxy or even mounting tape.
-David
Ocean Blue 2000 S
David N. is offline   Reply With Quote
Old 10-25-2006, 04:50 PM   #2
bmussatti
Posts: n/a
The part number was once covered in a post from MNBoxster. Send him a PM. or do a search.
Old 10-25-2006, 04:56 PM   #3
bmussatti
Posts: n/a
I thought you meant this part, but I may be wrong...sorry if I am:
http://www.986forum.com/forums/showthread.php?t=6468&highlight=rubber
Old 10-25-2006, 05:11 PM   #4
Thanks for replying. Yeah it's not that one, it's one of two little rubber flaps that fit on the belly framework behind the crankcase and in the middle between the rear wheels. I would guess they scoop air towards the transmission to help cool it. I did a few searches but just calling them rubber 'vents' or 'scoops' didn't seem to find anything. I'll get a pic next time the car's up to better show where they are.
-David
Old 10-25-2006, 05:26 PM   #5
Porscheectomy
You should be able to find the part number in here:
http://www.****************************************************.com/ref_por/Catalogues_USA_CDN/986_USA_KATALOG.PDF
Old 10-25-2006, 07:09 PM   #6
You don't want to glue it. It will be really hard to remove for maintenance or just get torn up when it needs to be removed. Get a replacement part and affix it the right way.
Old 10-25-2006, 07:28 PM   #7
I know exactly which rubber part you mean, I was under my car changing plugs, Oil, and brake fluid last weekend and kept scraping my arm on it.
I checked the exploded views in my PET catalogue, and the part isn't listed or even shown. No part # to go on.
Agree with others that it's best to replace it rather than try to tack it back on some way, because it's most likely <$20, probably <$10.
Contact your local dealer and see what they say (and report back here). I can't imagine it's integral to the entire Rear Cover (PN#986.504.119.00 - $108) - the piece it's attached to, and not available separately. Good Luck!...
Happy Motoring!... Jim'99
Old 10-25-2006, 08:28 PM   #8
http://www.renntech.org/forums/index.php?showtopic=2977
98Boxster98 is offline   Reply With Quote
Old 10-26-2006, 09:32 AM   #9
Porscheectomy
The rear Cover is $75 at Sunset, I just bought one.
Old 02-05-2019, 08:31 AM   #10
Flaps found
My Local Dealer spent some time to find this. The new one comes with some pins to hold it in. Each side is about $28. I do not have a part # but call Brumos Porsche at 9047259155. Provide them with this quote #: Q72484. At this time they had one in Atlanta and several in Penn.
jones904 is offline   Reply With Quote
Old 02-05-2019, 11:22 AM   #11
1998 Boxster Silver/Red
$28? $75? Ridiculous. Pfffffffffffffffft.
Purchase them from the Pelican site.
The scoops are $11.75 each. Need 2. Part # 986-331-361-03-M100
The retainers are $125 each. Need 2. Part # 999-507-774-40-M100
I'll be ordering mine this week.
1998 Porsche Boxster
Old 02-05-2019, 11:39 AM   #12
Thanks Starter986. No one at Pelican knew what I was talking about. Wish I had this info before. So it's called an 'axle joint air guide'. And the retainer typo should be $1.25 ea.
