Old 08-22-2020, 10:07 PM   #1
Cost of AOS Replacement Confusion. HELP
Hello everybody,
Just ordered AOS and blue clamp for my 99 Boxter. Online item is called an oil seperator. Same part? I am confused about why there is a wide range of cost that I have been quoted by mobile mechanics / shops. I have the 101 Projects for Your Porsche Boxter and it states this is a 2 hour job. Shop in town wants $1000 labor plus cost of part. Mobile mechanic wants to charge $500.00 labor. I don't want to be ripped off. Some say very easy job other's say pita. Thx.
mungodrums is offline   Reply With Quote
Old 08-23-2020, 04:44 AM   #2
husker boxster's Avatar
Double posting isn't a good idea as it splits the potential responses and discussion. Best to have it all done in one place. This section would have been the proper place to post, but most people probably read the general discussion area 1st, so that's where responses will appear. People would see your post here if you'd only posted here.
Boxster problems can sometimes seem like the end of the world is just a step away, but a little planning before posting a thread can go a long way to a successful response.
1989 928 S4 5 spd - black
Old 08-23-2020, 06:12 AM   #3
1998 Boxster Silver/Red
You only need a few tools for this job.
I changed the AOS on my 98 with zero Pirsche repair experience. I did plenty... plenty... plenty of reading... watched some vids... and decided to tackle it from under the car (remove passenger rear wheel) and above the engine. I would say the job is a 3 out of 10. What most you will need is patience. That's it.
You tackle that job... see how easy it is to save $500-$1000 and you'll wonder why you even considered the shop. You've got everything you need: The AOS anbd that clamp.
However... if you've the updated AOS you're going to need the updated hose/tube that crosses the top of the engine... the one running from the AOS to the TB.
When you go to remove the old AOS (We know you're going to tackle this job) just cut off the litle hose at the botom of the AOS (The one you're going to be replacing... the one for whic you'll use the new clip with the blue thing). I've read about guys that spend a crazy amount of time trying to remove the clamp of that bottom hose and when they're done... they just throw away the hose. So...
If you're going to throw away that tired old hose... just cut it off.
Bet you could tackle the entire job is a couple hours... maybe including jacking up the car... removing wheel.
The next time I have to replace my AOS it will take me an hour, maybe an hour fifteen, and that includes jacking up the car. Me? I'm not paying $500 to $1000 for that.
First read... watch vids... then ask questions! You can do this.
1998 Porsche Boxster
Old 08-23-2020, 04:27 PM   #4
98 Arctic silver 986
tommy583's Avatar
Starter WTF is wrong with you? I feel like i'm in the Twilight Zone . To the OP he is right you can do this.
Old 08-24-2020, 03:01 AM   #5
My spelling in that post was atrocious.
