Old 08-21-2020, 09:39 PM   #1
Can I manually position rear spoiler permanently?
Just got a 99 Boxter today. Spoiler dash light is on. Spoiler appears to be down. Can I manually leave it up all the time? If so, is this safe for handling, safety? Will light go off if I do this? Thx.
mungodrums is offline   Reply With Quote
Old 08-22-2020, 01:01 AM   #2
A liile different circumstance. My rear spoiler with John Toth ducktail is pinned to the up position. I removed the motor and transmission assembly so I can only move it up and down manually. Can't conceive any way leaving it up would be unsafe; you'll have a bit more drag until you reach the speed where it would have raised automatically. My light comes on when the circuit senses the spoiler didn't properly raise because I don't have any switches to tell the circuit where the spoiler is. The light resets when I turn the vehicle off and I'll disable the light when I can get my hands on a Durameteric.
Tony986Z is offline   Reply With Quote
Old 08-22-2020, 07:10 AM   #3
There Is No Substitute.
rick3000's Avatar
You could raise it and pull the fuse, it probably won't hurt anything except your mileage. It's not designed to be up below 50mph. The light is a different story.
Old 08-23-2020, 02:29 PM   #4
You can easily get rid of the light by adding a small wire in the connector for the spoiler
Old 08-24-2020, 06:53 AM   #5
JayG's Avatar
You could raise it and pull the fuse, it probably won't hurt anything except your mileage. It's not designed to be up below 50 75mph. The light is a different story.
FIFY it comes up at 75, not 50
Old 08-24-2020, 08:05 AM   #6
rick3000's Avatar
I know. It was designed to raise at 75mph and lower at 50mph.
Old 08-26-2020, 12:26 AM   #7
Thanks for the info and good pic Robert; I'll give that a try.
