Old 06-13-2020, 08:35 PM   #1
Eng.Temp with the new W/P.
Iam hoping that anything under 200 Deg's is good for Desert summer Temp's ?? Thanks Frank
flmont is offline   Reply With Quote
Old 06-14-2020, 05:24 AM   #2
2003 Base 5-speed
grc0456's Avatar
Looks dead on.
Old 06-14-2020, 07:08 AM   #3
Will there be cake?
tonythetiger's Avatar
Originally Posted by grc0456 View Post
Looks dead on.
a low temp thermostat could bring that down a bit, but that is dead on for stock 83 celsius thermo.
Old 06-14-2020, 07:02 PM   #4
Well Tony,..I did put the low temp Thermostat in..but temps yesterday were around 106,Deg's and I was also running my Air..Thanks Frank
Old 06-14-2020, 08:37 PM   #5
Racer Boy
Racer Boy's Avatar
If it was 106 degrees out, then I'd say the temp looks great!
Old 06-14-2020, 09:36 PM   #6
Wow, that's actually low for 106F! Definitely nothing to worry about.
Old 06-16-2020, 05:50 PM   #7
Will there be cake?
I don’t know, looks like it’s only 99 degrees, so let’s not start exaggerating...;-)
I’m just kidding
Old 06-16-2020, 09:43 PM   #8
Yea..I knew you were going to catch that..that was my 1st pic when I first started it up,..I was replacing the coolant ( it got to 185 quickly ) then I went cruising to help burp the system..
