Old 04-14-2020, 06:49 PM   #1
Boxster 986
Wolf's Avatar
Small bog on startup
Hey friends, not sure if this is an issue worth posting about but more of a conscious thing.
Usually after ive driven enough for it to warm up, stop somewhere, and go to start again theres a small bog where the rpm’s drop to about 500 and theres a small grinding noise (not terrible, more like a rattle) then goes back to normal. I’ve had good luck with starting it, most starts are very strong and start normally.
Not sure what the issue could be, couldn’t find any similar issues here.
Wolf is offline   Reply With Quote
Old 04-14-2020, 09:20 PM   #2
Terrible Tuner
JakeSFHunter's Avatar
Honestly, this can be anything.
The AC compressor can make the car bog. I had a similar issue with a dirty Idle Control Valve. When my AC would kick in the car would bog. I would have to give extra gas pedal when engaging the clutch.
I replaced the ICV and car idle way better and doesn't bog so drastically.
-Jason M.
JakeSFHunter is offline   Reply With Quote
Old 04-19-2020, 01:26 AM   #3
Boxster 986
Wolf's Avatar
I will look into that because that seems to be the case when the air it turning on and when its done it goes back to normal. Thanks.
