Old 04-07-2020, 05:21 AM   #2
Having experienced exactly the same problem that you have I'd almost certainly say that your problem is vacuum leak related. I d keep looking especially focussing on the throttle body connection...give those large hose clamps an extra nip up! Also check the large rubber o ring inside the oil filler cap.
Good luck!
jonogt6 is offline   Reply With Quote
Tags
hunting , idle , misfire , poor running , rough idle
