Old 03-10-2020, 01:57 PM   #1
Frunk intermittent
This problem has been dogging me a while. Did a search, to no avail. Sometimes the frunk opens normally, sometimes all I hear is the actuator, but it won’t open. Usually in warms conditions, hot weather, A/C on for example. 2004 base Boxster. Can the actuator cable stretch to the point it won’t work until it cools? Could it be a fan issue on the passenger side? Now it’s happening in NY, where the weather has been cool, whereas before it was summer weather. I’m stumped. Next time I open it, I will relocate the emergency cable to the tow hook area. I think I can can get to it if I pop the passenger headlight! Any advice appreciated. Thanks guys.
Blackcloud is offline   Reply With Quote
Old 03-10-2020, 03:26 PM   #2
Moderator
Mine was doing that. Lubed the latch and cable end at the latch. Works a treat now.
Bill Ladd is online now   Reply With Quote
Old 03-10-2020, 03:51 PM   #3
1998 Boxster Silver/Red
I believe the 2004 latch electronically is operated.
1998 Porsche Boxster
Old 03-10-2020, 06:48 PM   #4
I had that problem and fixed it by replacing the latch mechanism.
1941 Dodge Luxury Liner Coupe
Old 03-10-2020, 07:23 PM   #5
Moderator
Oh, yes. Maybe try lube anyway?
Old 03-11-2020, 09:18 AM   #6
It is electrically operated, and yes, it has been lubed.
Old 03-11-2020, 09:33 AM   #7
Side Porsche
My latch would open the first and sometimes the second time I did it. Then would make a noise but wouldn't work. I replaced mine but before I unplugged it I tested it. It just didn't have the same force pulling after the first couple of times.
2001 Silver Box
mipstien is offline   Reply With Quote
