02-22-2020, 02:03 PM
Sucking air as I rev it up,.!
I had this ( air sucking sound issue / problem)as well as Misfire codes on 4,5,6
300 304 305 306 and a P1238 (secondary fuel circuit )
1.changed plugs and coils on bank 2
2. pulled intake tubes to clean TB,..which was very oily and dirty,..I then cleaned the tubes because there was oil in them( could have added just a touch to much oil with my last change) redid a couple vacuum lines put it all back together runs a little better but slow to rev and it sucks alot of air from somewhere,.did the starter fluid trick no vacuum leaks no change in idle,but it sounds like a V8 with no air cleaner when I rev it up AOS lines seem fine AOS new last year also,..?? Thanks Frank
02-22-2020, 03:07 PM
Might have blown another AOS, I would pull all the spark plugs out & inspect for oil. If the plugs are really oily crank the engine over with the key to see how much oil comes out.
02-22-2020, 06:41 PM
Ok..I pulled bank 2 plugs and yes they were carboned up and threads were oily,.but I did not pull bank 1 but I will tomorrow,.this is the second AOS installed in 1 and a half..When I pulled my oil cap there's no change in Idle that I can tell any way..Thanks
02-23-2020, 07:00 AM
1998 Boxster Silver/Red
Which brand AOS are you running?
1998 Porsche Boxster
02-23-2020, 09:29 AM
P/N 996.107.023.04 oil separator. undated MAF sensor 986.606.125.01
both done 6/6/2018.
they charged 129.00 for the AOS,...and 360.00 for the MAF
then replaced AOS on 10/22/2018 under warranty
I have no idea where they bought the parts.
02-23-2020, 01:08 PM
If the AOS is bad... or going bad... when you try to remove the oil cap it will be challenging given the suction. I learned on these pages that's a sign of a bad/failed AOS.
Now... my AOS has ~ 13K on it and, last month when I tested it (for the heck of it)... the oil cap came off without struggling but... with the cap removed it started idling differently than normal.
That when you remnove your oil cap and notice no changes in the engine running may be a sign, for wiser minds, that something else is in order to be checked. Hang in there. Someone will land on it for you.
02-23-2020, 05:38 PM
Via 101 projects,I disconnected the AOS tube and plugged each end and YEP,..the sucking noise was gone,.still ran a bit rough tho but at least that loud sucking noise is gone,.And there was oil in that tube going to my newly cleaned TB,...I hope the Porsche brand is the best replacement part,.
why such a complicated process, Why cant you just run a tube from Case to TB,.?? Frank
PS oil cap came of easy,.but the intake side sure had some vacuum, It was not easy to remove my thumb from that TB tube as soon as I did it stalled.
02-26-2020, 11:52 PM
Yeah, AOS, water pumps etc really are best to use factory parts. Some say aftermarket are fine, but really, given they aren’t the easiest things to swap, why chance it?
02-29-2020, 03:40 PM
I bought the porsche factory AOS...would it be easier to pull the oil filler tube to change the AOS unit,.no way my hands can get to the top hose with that tube in the way..?
02-29-2020, 06:09 PM
Why yes it is easier to disconnect the oil fill tube,..Aos removed and replaced in the time I asked the oil tube question..!!
