Old 02-23-2020, 01:08 PM   #6
Starter986
1998 Boxster Silver/Red
Originally Posted by flmont View Post
Ok..I pulled bank 2 plugs and yes they were carboned up and threads were oily,.but I did not pull bank 1 but I will tomorrow,.this is the second AOS installed in 1 and a half..When I pulled my oil cap there's no change in Idle that I can tell any way..Thanks
If the AOS is bad... or going bad... when you try to remove the oil cap it will be challenging given the suction. I learned on these pages that's a sign of a bad/failed AOS.
Now... my AOS has ~ 13K on it and, last month when I tested it (for the heck of it)... the oil cap came off without struggling but... with the cap removed it started idling differently than normal.
That when you remnove your oil cap and notice no changes in the engine running may be a sign, for wiser minds, that something else is in order to be checked. Hang in there. Someone will land on it for you.
1998 Porsche Boxster
