02-20-2020, 09:17 PM
Newby needing help
Couldn't get windows to role up on my 97 986, as last resort I removed the relay for the convertible top and windows worked. Anyone have any idea what to check next, I am guessing its a switch having something to do with the top. If anyone else had this problem and was able to correct it, I would greatly appreciate the help. Thanks, great forum and excellent info.
02-20-2020, 09:20 PM
Who's askin'?
Did they roll up halfway but no further? Or didn't work at all?
02-21-2020, 07:32 AM
They didn't roll up at all, just clicked!
02-22-2020, 12:33 PM
I had this problem. Trying to rack my brain as to what was causing it.
I think I recall it being a fuse. Check the fuses correlated with the convertible top.
'97 - Silver (rebuilt/stripping)
'99 - Black (rebuilt/sold)
'01 S - Rainforest Green (daily)
'03 S - Orient Red (sold)
02-23-2020, 12:53 PM
Will check fuses!
02-24-2020, 04:31 PM
all fuses are good.
02-24-2020, 04:48 PM
Are you sure you're getting the relay back in all the way? That big thing takes a fair bit of force to pop in.
Any problems with the convertible top function? Or is it just the windows?
I definitely didn't replace any electrical parts when I was fussing with he '99 (the one that had the problem). I did have to replace a few fuses, though I don't remember which ones. I also recall having removed and replaced(not a new one) the convertible top relay for some reason. I probably sprayed the contacts with some QD contact cleaner, since that's my standard practice when removing electrical components. Maybe try that, then make sure it's really in there good.
I had a friend help me with some of the work on that car(his car now), but I don't think he was around when I did the electrical stuff. I'll ask him if he remembers anything about it. I apologize, I don't know why my memory is so fuzzy on the subject.
02-24-2020, 09:58 PM
Thanks for all the possibles, I'll check to make sure the relays all the way in, didn't really use much force to put it in last time.
02-25-2020, 10:47 AM
Checked relay, in tight, still preventing windows from raising, relay out - windows work fine. Is there any other source that might provide an answer, this is driving me crazy.
02-25-2020, 11:08 AM
Try messing with the windows with the top in all of its orientations (up&clamped, unclamped, down). See if that changes anything.
02-25-2020, 02:39 PM
will try it. Just by chance does anyone happen to know the pin identification for the relay, figure I could test it to ensure it's good.
02-26-2020, 02:54 PM
If the relay is suspect, try giving it a good smack against a hard surface. This has fixed several faulty relays for me.
