Old 10-17-2019, 02:40 AM   #1
truegearhead's Avatar
Relocated airbox and intake to rear window
I had a minor problem installing a 2.7L engine with a cable throttle, the throttle plate was further back and my intake tube no longer worked. Sure I could have made something work but I decided to pull the whole airbox out of the engine bay instead. OK mostly I was board. I also added some engine cooling ducts.
1997 Boxster 4.2L Audi V8 Bi-Turbo
2003 911 C2
NASA HPDE Instructor
truegearhead is offline   Reply With Quote
Old 10-17-2019, 06:57 AM   #2
edc
550 Anniversary
edc's Avatar
Why not go for the bigger airbox if doing that? Also what is the flexi hose made of? I have seen flimsy ones collapse under pressure and restrict at and power.
Old 10-17-2019, 09:33 AM   #3
Well I cut the airbox in half so its very open now, I can't imagine a bigger airbox would be more efficient for this engine but I could be wrong. There's two kinds of tubing there: one is the air intake which is aluminum piping and forced induction silicon elbows. The hoses are just cooling for the engine, they're not under pressure. The bottom picture gives you a better idea of whats going on.
2003 911 C2
Old 10-17-2019, 11:03 AM   #4
Isn't that a low pressure area? Maybe better to have the air enter from the roof. Just thinking out loud..
Robert986 is offline   Reply With Quote
Old 10-17-2019, 11:24 AM   #5
Ya....it definitely is. We’ll see how it does.
2003 911 C2
Old 10-17-2019, 12:53 PM   #6
The Radium King's Avatar
post 91 ...
Boxster Subaru conversion interest?
or perhaps item #26274 ...
https://www.factoryfive.com/order-a-kit/gtm-supercar-kit/
Old 10-18-2019, 06:12 AM   #7
Motorist & Coffee Drinker
78F350's Avatar
I like it. If you do want a higher pressure location for the intake, start by looking back at the aerodynamics at 180 km that Fred posted.
Boxster 986 Aerodynamics @180km/hr
Or better, just buy the sexy scoop (linked from one of TRK's old posts, the P-bucket links from the Subaru thread don't work well for me.). Bring the air to where you mounted the box.
