Old 07-10-2019, 05:18 PM   #1
Are O2 Spacers required for Max-flo on 986?
I’ve recently installed the Fabspeed Maxflo Performance Exhaust System on my 03 Boxster. It is great however, since then I keep getting error codes - P1101 [input variables charge measurement] & P1126 [oxygen sensing adaptation lower load, bank 1]. I clear the codes and it is fine for a few days, and then suddenly they are back. I do note that the CEL doesn’t come on. I only know about it as I checked with Durametric after install.
I am running a stock air filter, but not sure of the car’s history (before 2015) I cleaned both the MAF and throttle body. Suspecting air leaks, I checked for excessive vacuum on the oil filler cap, not really evident, but not knowing how long the AOS has been in – I replaced it anyway. I also replaced the O2 sensors (new Bosch). Got a new gas cap too just in case the old one was part of the problem.
I took it to an indie Porsche mechanic and he can’t find fault with the exhaust install or any air leaks either (visual inspection – not a smoke test).
I haven’t seen a P1124 code only P1126 and occasionally a P1101 (once a week).
I have seen that on some exhaust applications that O2 spacer is required. Should that be something I should try? Or given that the CEL doesn’t actually come on (runs smooth and idles fine) – is this a problem I can ignore?
Tigger19 is offline   Reply With Quote
Old 07-10-2019, 07:48 PM   #2
Artist, 986S tinkerer
NewArt's Avatar
If the code keeps coming back, eventually you will get a cel if you don’t clear the codes. I have a similar problem with my headers and high flow cats. I’m hoping to get my tune adjusted to compensate.
Old 07-10-2019, 08:06 PM   #3
Thanks so maybe instead of O2 spacers I look at fuel trim values instead? Although not sure why only bank 1 ??
Old 07-11-2019, 10:08 AM   #4
BYprodriver's Avatar
Yes, might be fuel delivery issue, clogged fuel injector etc. Inspect spark plugs.
Old 07-11-2019, 05:43 PM   #5
OK. I forgot to add I replaced coil packs and spark plugs at last service only 2000 miles ago. I ran a can of injector cleaner through at that time too (do this every service) but I will look at the plugs condition again as suggested.
Old 07-12-2019, 03:02 AM   #6
Got a P1126 & P1133 error today which I believe could be MAF. I cleaned it and re-I stalled it. Cleared codes and went for a long drive. So far so good. I might have to get a new one before it fails completely.
Thanks for the advice.
Old 07-12-2019, 04:02 PM   #7
Also forgot to add I replaced all coil packs and spark plugs at the last service 1000 miles ago and as routine I run a bottle of injector cleaner through every service. I will still look at plug condition anyway as advised.
All the better if all the plugs look good you must have crossed some of the coil wires.
