Old 06-09-2019, 05:00 AM   #1
Front suspention torque values
After discovering a slight crack in the front subframe i changed the frame, now I need to torque it all up to specs..
So far I have not found a definite value for the two M10 bolts tightening the steering rack to the subframe. One value I found is 47NM and another is 65NM.
Anyone know for sure? Thanks in advance!
Old 06-09-2019, 05:11 AM   #2
You should buy an electronic shop manual on eBay. It has all the torque values and also complements the 101 Projects and Bentley DIY guides beautifully.
1941 Dodge Luxury Liner Coupe
Old 06-09-2019, 12:21 PM   #3
I torqued it to 47 NM and added thread locker. Felt fine :-)
Old 06-09-2019, 02:52 PM   #4
My factory manual, which does not have recent updates, shows 65 Nm / 48 lb-ft.
spendy is offline   Reply With Quote
Old 06-09-2019, 05:27 PM   #5
Ciao's Avatar
Updates typically go for more torque than less
5280 Cruising @High Altitude
Seal Gray & K&N Filter
Old 06-10-2019, 01:48 PM   #6
Excellent, thanks! I re-torqued to 65NM, actually felt more reasonable than 47.
Old 06-19-2019, 06:34 AM   #7
I removed this comment and started a separate thread
