Old 05-04-2019, 11:29 AM   #1
truegearhead's Avatar
Shorter flywheel bolts for lightweight flywheel
I just tried to install a used light light flywheel and noticed that the factory bolts are too long. Does anyone know where to buy shorter ones? I can’t seem to find them.
Cheers,
Stu
1997 Boxster 4.2L Audi V8 Bi-Turbo
2003 911 C2
NASA HPDE Instructor
truegearhead is offline   Reply With Quote
Old 05-04-2019, 01:44 PM   #2
Who's askin'?
maytag's Avatar
McMasterCarr.com
Old 05-04-2019, 02:59 PM   #3
my favorite store (So.Cal) for awkward and hard to find metric hardware is McFaden-Dale I found them a couple of decades ago when looking for uncommon size bolts
for the Fiats and Alfas..
Old 05-04-2019, 03:53 PM   #4
The Radium King's Avatar
m10x40. just measured mine.
Old 05-05-2019, 04:35 AM   #5
Most larger cities will have at least one or two stores that specialize in hardware.
Looks like southern fasteners is in your city Southern Fasteners & Supply Company - Quality Parts and Services
Woody
Old 05-05-2019, 04:56 AM   #6
Awesome! You all rock.
2003 911 C2
Old 05-05-2019, 06:23 AM   #7
Racer Boy
Racer Boy's Avatar
Yes, we all do rock!
Old 05-05-2019, 02:07 PM   #8
BYprodriver's Avatar
Cheers,
Stu
I would cut the new factory bolts.
Old 05-05-2019, 07:49 PM   #9
dremel... ? :-)
Old 05-06-2019, 03:47 AM   #10
steved0x's Avatar
We have a Fastenal down here, if you have one close by you can take in the old bolt. They have a good selection of metric.
Old 05-06-2019, 09:11 AM   #11
1998 Boxster Silver/Red
dremel... ? :-)
Yup. Dremel it off (measure twice, cut once) and feather the end. You should be good to go!
1998 Porsche Boxster
Old 05-06-2019, 12:28 PM   #12
dremel... ? :-)
Thin cutoff wheel, when you buy the bolts make sure to get the same grade as the stock bolts & buy a couple nuts to fit the bolts. Thread a nut onto the bolt before you shorten the bolt, & then removing the nut restores the threads as you remove it.
Old 05-06-2019, 02:03 PM   #13
You can’t cut them unfortunately the shoulder is too long. I found some replacement 8.8s at Home Depot.
2003 911 C2
