Old 02-11-2019, 05:43 PM   #1
Top down
Send a message via Skype™ to Pastor T
Boxster drive axle
I have a 2000 Boxster Base 2.7 5-speed manual. Are the drive axles different part numbers from the Boxster S 3.2.
Can Boxster S 3.2 6-speed manual axles be used on a Boxster base 2.7 5-speed manual.
And where is the best source for buying axles.
VT
every day is a great day when you are driving a Boxster
Pastor T is offline   Reply With Quote
Old 02-11-2019, 05:58 PM   #2
The Radium King's Avatar
5-speed and 6-speed axles are different. i've had bad luck with aftermarket axles. try woody or ebay for a low-mileage used oem axle.
Old 02-11-2019, 06:02 PM   #3
Top down
Thanks Radium King
Old 02-12-2019, 06:01 AM   #4
The 6 speed axles are different but all 1997-2002 5 speed axles are the same. I don't have any manual axles
Woody
Old 02-12-2019, 06:49 AM   #5
steved0x's Avatar
I went down this route when my axles (2000 S 6 speed) were venting liquified grease out the axle vent hole due to to heat. Ultimately I uninstalled the axles, cleaned out the old grease with Kerosene and the acetone, and repacked with Redline CV-2 grease and new axle boots, and have had no problems since. If your axles are not clicking and/or obviously ruined, just rebuilding your existing axles might be the best bet?
