Old 02-01-2019, 08:30 AM   #41
78F350's Avatar
Originally Posted by Blackroot View Post
Weird. I wonder why folks sell case halves singly. All over Ebay.
Just because a thing is offered for sale on eBay, doesn't mean anyone should buy it.
Used IMS Bearing
Old 02-01-2019, 08:40 AM   #42
Who's askin'?
maytag's Avatar
'cuz guys like me make coffee tables out of them.
I've got a Ducati Case-Half in my office right now..... they're great "trophies".
Old 02-01-2019, 08:51 AM   #43
Hello Maytag,
Care to share a picture of the Duc half case..?
Old 02-01-2019, 08:55 AM   #44
Grant, the heads and valves “seem” to have escaped damage but I’ll have to take a close look.
Hello NewArt,
I know that you can use the 3.6 crank on your 3.2, but not 100% sure about the heads,
perhaps BYProdriver can chime on this, as you could end with a killer engine with your 3.2 cylinders bored to 3.8 using the LN Nickies..
PS: I better get back to work ..lol
Old 02-01-2019, 09:02 AM   #45
Who's askin'?
maytag's Avatar
Hello Maytag,
oh... of COURSE!!! hahaha.... Twist my arm to make me talk about bikes! :-)
But we should probably take it to another thread so we don't hijack this one.
Gimme a minute. I gotta pee first. :dance:
(I really don't need to pee... but everytime I see that little guy dancing, I think of the Pee-Pee dance)
Old 02-01-2019, 01:26 PM   #46
elgyqc's Avatar
Hello NewArt,
I think the problem is that the 3.2 crank case has a big hole in it...
Grant
Old 02-01-2019, 01:31 PM   #47
Used IMS Bearing
LMAO
Blackroot is offline   Reply With Quote
Old 02-01-2019, 01:46 PM   #48
Used IMS Bearing
LOL - that's one expensive paperweight!!!
"Cool Prius!"
- Nobody
Old 02-01-2019, 03:57 PM   #49
Side note, 3.2 complete engines in working order from 3k to 6k usd $
Mileage all over the place
I believe your goal was a 3.4 intact though? Sorry, thread is all over the place
Old 02-01-2019, 05:01 PM   #50
Artist, 986S tinkerer
NewArt's Avatar
Originally, I was looking for a 3.2 replacement. Almost all of the available engines of this format are 5 chain (pre 2003) engines. The 3.2 three chain motor appeared in the Boxster in 2003 with the 7.8 DME. It was succeeded by the 3.4 in the Cayman and then in the Boxster.
On the other hand, the same 3 chain motor appeared in 2002 in the Carrera, also using the 7.8 DME. This engine was bored out to 3.6 with better breathing and tuning. This is why I bought the 3.6 which you see in these pictures. Supposedly the core was intact and was therefore a candidate for a rebuild with “Nickies” and all. Ah well, a lesson learned. :ah:
Old 02-01-2019, 05:20 PM   #51
So, here's the update. Structure looks okay. Sleeves are a bit wanting. Better than I thought. Crank looks fine, but what do I know?
Does anyone know how much D-chunking is too much to be repaired with LN Nickies? In my mind I figured they welded the broken chunks back in to the block before machining everything and inserting the liners. If no one knows for sure it would worth contacting LN to find out. But this picture does look like a Triple D Chunk - 2 sides on one cylinder and one side on another. Sorry for your loss...
Old 02-01-2019, 06:07 PM   #52
NewArt's Avatar
This photo shows the bottom of the cylinders not the top. The head is lying top down on the table.
Old 02-01-2019, 06:44 PM   #53
I assumed that that the D chunk failures happen at the bottom of the cylinders (opposite side of the heads).. of course I could be wrong..
Regardless, these cylinder halves are junk
Old 02-01-2019, 07:14 PM   #54
NewArt's Avatar
Yes, you are right on both counts: the damage happens on the bottom of the cylinder and, this bank is good for aluminum recycling.
Old 02-02-2019, 07:08 PM   #55
elgyqc's Avatar
Well if you want to start all over again...
https://losangeles.craigslist.org/sgv/pts/d/987-porsche-boxster-motor-61k-miles/6786539643.html
Grant
Old 02-02-2019, 07:19 PM   #56
Originally Posted by elgyqc View Post
Clutch too !
Old 02-02-2019, 08:26 PM   #57
NewArt's Avatar
Wow, I must say that that one looks pretty nice!
Old 02-03-2019, 07:59 AM   #58
There are some relatively low mile used and a couple of rebuilt engines on eBay right now. This one says it is a 987 3.2 factory rebuild for 14,900 or best offer. There are also some 3.6 engines listed.
Old 02-03-2019, 08:34 AM   #59
Who's askin'?
maytag's Avatar
Man.... I'd JUMP on that one!
Old 02-03-2019, 12:34 PM   #60
NewArt's Avatar
IF it’s what it seems to be! :chicken:
