Old 12-26-2018, 04:12 PM   #1
1999 2.5 Crank Turns Cams Don't
Left Bank bent all of the exhaust valves, broke the cam chain, and peeled the teeth off of the exhaust cam.
Chains from Heads to IMS are still intact. (they don't move with the crank) Removed heads and IMS bearing retainer. Crank turns, back of IMS turns. So the crank to IMS chain is intact. Appears I-shaft is no longer connected to the crank drive sprocket?
Is there a keyway, spot weld, shear pin, flat spot??? What connects the shaft to the drive sprocket?
Misfire is offline   Reply With Quote
Old 12-26-2018, 04:37 PM   #2
I believe its just a press/friction fit.
Old 12-26-2018, 04:54 PM   #3
seningen's Avatar
Just press fit.
I’ve seen them pulled and then pinned
Mike
Drivers: '15 Panamera Hybrid (wife's), ' 01 996 GT2, 00 Boxster S, '96 993 Çab/Tip (wife's)
Race Cars: '75 911 RSR Replica & '99 Spec Boxster
mike@lonestarrpm.com
seningen is offline   Reply With Quote
Old 01-12-2019, 09:29 AM   #4
Man, what a disaster, I`m sorry for your loss. Interesting fail that I`ve not heard about before. I wonder what happened first: the camshaft seized and forced the sprocket to turn around the IMS, or, sprocket disengaged from IMS and caused the disaster in the head? How about the right bank? That should be a mess too if the cams don`t move with the crank. Any update on this?
