Old 12-18-2018, 08:51 AM   #1
Flywheel install question
Quick question-
Is it possible to install the flywheel incorrectly ?
I know the dual mass has a small post that fits into a hole on the mounting side, but if it isnt aligned with that post, are you able to torque it up ?
I have the bolts in and at the initial 19ft lbs (not yet the 120 degrees), and it seems flat, but how to know for sure that post is in the hole ?
2004 Boxster S
Blackroot is offline   Reply With Quote
