Old 12-03-2018, 04:24 PM   #1
Replacement cluster
I bought a used cluster for my 2002 base. Will I cause a problem with the cluster or ECU if I connect the replacement in to make sure it's working and to check the mileage, and then to switch back?
harrg67 is offline   Reply With Quote
Old 12-03-2018, 04:31 PM   #2
No, that won't cause any issues.
Old 12-03-2018, 04:54 PM   #3
Be careful with the harness connections as they're very brittle at this age
Woody
Old 12-03-2018, 05:15 PM   #4
Pathological Tinkerer
This x10. I have broken all three in my various cluster projects.
P_Carfahrer is offline   Reply With Quote
Old 12-03-2018, 06:33 PM   #5
Thank you for the advice! I will take care for sure.
Old 12-12-2018, 04:33 PM   #6
Wow, not that I doubted you, but you weren't kidding ab9ut brittleness. And I've seen single use Rubbermaid using thicker plastic. Both blue and green connectors lost the side pins for the black locking lever and the left mount point for the cluster snapped off. And I was being gentle... Yikes
