Old 11-21-2018, 06:46 AM   #7
kk2002s's Avatar
There is a fuel pump relay that is meant to shut it down in case of accident. Mine went bad, it would over heat and stop the fuel pump. It would cool down then work until over heating again. Seems that if it could over heat and stop the pump, it could possibly go the other way and melt turning on fuel pump. I diagnosed using jumpers and when I jumped over the relay to ON, the pump would just run, I think even with the key off.
Seal Grey
