10-15-2018, 03:15 PM
Used Oil Analysis Experts...if I drive...
200 Km to a storage facility and shut her down for winter after putting in fresh oil, am I defeating the purpose of fresh oil for storage?
986 00S
10-15-2018, 03:50 PM
No, but more steps should take place for winterizing the P car.
5280 Cruising @High Altitude
Seal Gray & K&N Filter
10-15-2018, 04:27 PM
Racer Boy
Nope, not defeating the purpose.
10-15-2018, 04:54 PM
There Is No Substitute.
It's better than putting in storage with old oil, but not as good as putting it in storage immediately after the oil change. If you can't change the oil where it's stored, then it's the best option you have.
10-15-2018, 05:12 PM
Since my opinion is that you would need to start and run it immediately after change to purge the Dirty/contaminated oil from the engine passages, bearings etc. anyway, No Harm No Foul.
10-16-2018, 03:35 AM
I've been doing UOAs and winter storage of Porsches for over 13 years. Some years the oil has as little as 200-300 miles on it at shut-down-time. Other years, it has 2,000-3,000 miles on the oil. On rare and perfectly timed occasions, it's been as low as 20-30 miles. My UOAs have all been excellent, and I've never seen any indication that the mileage mattered. My cars get driven during the driving season, use high quality A40 approved oil, and change every 5K miles.
10-16-2018, 06:57 AM
I do about 500 to 1500 Kilometers on mine per year then I store it and take it to the dealer in the spring, they do a checkup of the car change the oil and then I'm good to go.
Frank
10-16-2018, 01:01 PM
This is bass ackwards.
10-16-2018, 01:27 PM
[QUOTE=Flavor 987S;581133]This is bass ackwards.[
What?
Frank
10-16-2018, 03:43 PM
[QUOTE=p3230;581139]
What?
I don't understand all of this in detail, but it's my understanding that motor oil, as the car is driven, develops acids and other baddies that are less than ideal for allowing to sit over the course of the winter. If you're changing your oil on a 3-5k miles regular basis, the effect may be pretty slight. Again, I don't know for sure. But, on recommendations that have come from this forum, I have started changing the oil just before putting her to bed for the winter. FWIW.
10-17-2018, 08:02 PM
[QUOTE=Frodo;581141]
Thank guys for all your thoughts.....yes its the reintroduction of acids into the oil that was on my mind. Usually, I put in fresh oil drive a short distance and then shut it down. This time I am stuck.
986 00S
10-16-2018, 01:09 PM
Do it. I'll confess I never worried about it because I was able to take the car out for a 15-30 mile to work drive every few weeks, the oil got hot and the water vapor burned off so the car was next put away pretty much water vapor free. What you don't want to do is put the car away after a series of very short cold drives.
10-17-2018, 06:42 AM
+1 on what Mike says. While living in the Catskills I generally put less than 1,500 miles a season on my 986. I changed the oil and filter at the beginning of the driving season and I made sure my immediate pre-storage run was at least 60-70 miles to be sure that all of the vapors were burnt off.
There is certainly no harm to changing the oil and filter as part of the winterizing routine but the more important point is to be sure each time you drive the car you drive it long enough to burn off the vapors. Serial short cold engine drives (even in the summer season) are major contributors to oil contamination.
Rgds, Fred
10-17-2018, 08:17 PM
Nothing really to worry about here...
If anything, you should not let the car sit for long time, just run the engine and drive the car more often.
10-17-2018, 11:12 PM
Here in Co we have winters, but we also get warming days as well. I put mine in a semi stored state, but still gets driven when reasonable (I don’t do winter tires and don’t run my summers when it is really cold) I change my oil early spring, and maybe after summer if I have done a few track events. Not been an issue...
