Old 10-06-2018, 06:37 AM   #1
Ciao's Avatar
Humidity/Participation vs Brake Fluid
One of the reasons and the purpose of flushing the brake fluid ~ 2 years is because it absorbs moisture. Does it make sense to flush the brake fluid in a humid climate or rainy day because it may absorb the moisture in the air as you replace it?
5280 Cruising @High Altitude
Seal Gray & K&N Filter
Old 10-06-2018, 07:22 AM   #2
Lew
So Blessed!
Lew's Avatar
I have one of these and the Indie Seth in Jax FL uses one of these when doing a inspection. It will tell you if your brake fluid has a certain level of moister. I just checked the Brake fluid in my Truck and it has been over two years and needed to be changed. Moister was bad! Better pedal now since changing fluid.
https://www.walmart.com/ip/Brake-Fluid-Moisture-Tester-Auto-Car-Truck-Diagnostic-Testing/169181238
Artic Silver Boxster S - Black Leather - Black Top - Convience Plus Package
Lew is offline   Reply With Quote
Old 10-06-2018, 02:53 PM   #3
Participation or precipitation?
You don't need to worry about the time (~1 hour) that the fluid is exposed to the air (whether humid/rainy or dry) during the flush and bleeding procedure.
You do need to worry if you left the reservoir cap off for a week.
Old 10-06-2018, 03:38 PM   #4
Ciao's Avatar
Perhaps I was being too critical.
Lol! Precipitation is the correct term.
