Old 06-20-2018, 04:41 PM   #1
Boxster without fuel injector pulse on #6
I have a quick question.........I have a miss on Cylinder 6. Noid light shows no fuel pulse signal on #6. There is power, but not getting the ground signal to the injector. Can anyone tell me where the signal ground comes from? Looked for the pinout for the DME, but no clear answer. Any info would be helpful. Thanks.
isocyn8 is offline   Reply With Quote
Old 06-20-2018, 11:08 PM   #2
The Radium King's Avatar
what year is your car?
Old 06-21-2018, 05:08 AM   #3
It’s a 1997
Old 06-25-2018, 11:46 AM   #4
bump
anythought?
Old 06-25-2018, 12:52 PM   #5
Motorist & Coffee Drinker
78F350's Avatar
A quick look at a '97 diagram I found online shows that the ground for the pulse comes from pin 33 on the DME.
Old 06-25-2018, 03:31 PM   #6
Thank you
I will try to chase that down, I was able to find the Positive side being number 16. Thanks
Old 06-28-2018, 10:38 AM   #7
Dead injector ground
I ordered a used engine wiring harness for the Boxster. I am hoping it is in better shape, but who knows. I tried removing the sheathing on the current harness and it quickly became clear that there is more going on in there than I am equipped to deal with. Even if I found the broken wire wrapping it all back up together in some kind of orderly fashion seems impossible. I will report what happens when I get the new harness.
