Old 06-02-2018, 02:37 PM   #1
geraintthomas's Avatar
Quick vacuum confirmation
If I have a vacuum leak somewhere (for instance, a cracked oil filler pipe), the SAI's check valve won't open at all as it's run on vacuum, causing the SAI pump to be blocked.
Correct?
Porsche Boxster S Type 986
Old 06-02-2018, 06:10 PM   #2
Depends on the severity of the leak, but the short answer is yes, it will keep it from opening.
Old 06-03-2018, 01:17 AM   #3
Severe enough to have a substantial performance impact on the car, and to throw lean EML's? I thought I had two issues, a vacuum leak and the SAI issue, but I think it's just one big vacuum leak.
Old 06-03-2018, 03:10 PM   #4
BYprodriver's Avatar
Vacuum leaks suck
Old 06-05-2018, 04:58 AM   #5
Ummm. Sorry to be a pain, but what does SAI stand for?
2001 Boxster S, TipTronic in Seal Grey aka "The Imp"
2001 TE50, ESS in (now) Grigio Titanio Matallizzato aka "The Golden child"
TrumpyAl is offline   Reply With Quote
Old 06-05-2018, 04:59 AM   #6
Secondary Air Injection (pump)
Old 06-06-2018, 05:20 AM   #7
Beginner
Jamesp's Avatar
Vacuum leak is on the check list for SAI codes.
2003 S manual
