Old 05-20-2018, 12:19 PM   #1
Replaced MAF sensors with cheap sensors and check engine light still on
I replaced my MAF sensors with 2 new ones from carparts.com and check engine light came back on again same code P0102. Could it still be a bad MAF sensor and just replace it with a bosch?
scott17201 is offline   Reply With Quote
Old 05-20-2018, 12:33 PM   #2
Your car has two MAF sensors? Weird...
Yes, stick with Bosch.
Old 05-20-2018, 01:19 PM   #3
P0102 indicates that you either have a wiring break or short to ground. An new MAF will not fix this, you need to find the wiring issue and fix it.
Old 10-04-2018, 02:37 PM   #4
To clarify, there are two MAF sensors? Where is the second one located?
Dave2001S is offline   Reply With Quote
Old 10-04-2018, 02:41 PM   #5
In his imagination………………...
Old 10-04-2018, 04:13 PM   #6
1999 base
Meir's Avatar
Maybe you mean o2 sensor (Aka lambada)?
There is only one MAF sensor located next to the air filter.
The o2 sensors are located on the exhaust, before and after the catalytic converter.
4 in total, 2 for each side.
What faults codes do you get?
Anyway, I think that the word “cheap” is the cause of your problem.
You need to use OEM or at least OE part, with the exact part number as the one removed.
