Old 04-30-2018, 12:49 PM   #1
rggav
Can;t remove front Oxy Sensors
Tried for three hours to remove my front two Oxy sensors from my 2000 Boxster S. They would not budge. Tried everything, PB Blaster, heat. Nothing worked. Then I took it to a local shop and they could not remove them either. I do not believe they have ever been replaced.
WHAT NEXT??
RG2000S is offline   Reply With Quote
Old 04-30-2018, 01:09 PM   #2
Just been there. Basically mine had welded themselves in after 15 years of heat cycling. I had the cats out and got one out but stripped threads.
Took them to an exhaust builder to cut out the existing ones and weld in new stainless steel bungs so I can install new O2 sensors.
Detailed thread on the Irish Porsche club forum so will add link to that so you can see all the info.
Sent from my iPhone using Tapatalk Pro
Traco
_________________
Older but no wiser.
2003 Boxster S, Seal Grey
Traco is offline   Reply With Quote
Old 04-30-2018, 01:10 PM   #3
Link to complete thread on my exhaust battle. It might help you.
http://forum.porsche-club-ireland.com/index.php?topic=8501.0
Traco
_________________
Older but no wiser.
Old 05-03-2018, 02:31 PM   #4
Update:
Cats back. One bung cut out and replaced, the other survived by running a tap down it.
All reinstalled and no error codes.
Traco
_________________
Older but no wiser.
Old 05-04-2018, 04:12 AM   #5
What did you put on the threads of the O2 sensors to prevent it happening again in the future ?
rfuerst911sc is online now   Reply With Quote
Old 05-04-2018, 05:00 AM   #6
Hopefully, high temp anti seize.
The threads on this sensors is fortunately the same as a spark plug, so the spark plug thread chaser sold at most auto parts stores will clean them up.
Old 05-04-2018, 07:43 AM   #7
Last time I replaced O2 sensors they came with anti-seize applied.
1941 Dodge Luxury Liner Coupe
Old 05-04-2018, 02:58 PM   #8
Milk of Magnesia also works great , a tip handed down by a great Porsche mind .
Old 05-04-2018, 03:24 PM   #9
That stuff used to seize the lid on the bottle?!?!?
Traco
_________________
Older but no wiser.
Old 08-29-2019, 06:28 AM   #10
Thanks for this post, Traco. This is exactly the problem I had this week. I am going to take it to a shop to have it welded this weekend. Cheers!
~Charles
Originally Posted by Traco View Post
Update:
charlessimon986 is offline   Reply With Quote
Old 08-30-2019, 06:24 AM   #11
If you're replacing the O2 sensor cut (or break) the end of the sensor off and then use a normal socket on a breaker bar to get it loose.
If you have access to a torch try to get the bung red hot first.
Chi-Town is offline   Reply With Quote
Old 08-30-2019, 12:43 PM   #12
01 Basalt Metallic 986
JimmyBad's Avatar
I have a set of cats I’m letting go. PM if interested.
JimmyBad is offline   Reply With Quote
