Old 03-19-2018, 03:48 PM   #1
Smile Wheel Offset Question
Hello Folks,
Thought i'd ask around before i consider this set of wheels..
18 x 7.5 (front) ET50 part# 99336213406
18 x 9 (rear) ET 52 part # 993362138.01
Will they fit NO problem?
I intend to install them on my '04 986S, Wheels stamped Made in Italy, are they original OEM or aftermarket? Seller does not have a clue, but says its 100% OEM?
Thanks for the info...
t2
t2-bxtrs is offline   Reply With Quote
Old 03-19-2018, 04:25 PM   #2
Ciao's Avatar
They are original probably came off a 2000 Boxster
5280 Cruising @High Altitude
Seal Gray & K&N Filter
Old 03-19-2018, 05:51 PM   #3
Artist, 986S tinkerer
NewArt's Avatar
They will fit perfectly.
Old 03-19-2018, 06:37 PM   #4
steved0x's Avatar
I think some of the oem wheels were made in Italy, does it have "Not original equipment" or similar stamped on the inside? If it has wheel width and offset embossed by the Valve stem it is likely OEM, although at least one of the oem twists doesn't.
Old 03-19-2018, 07:00 PM   #5
eicheldp's Avatar
I used the following site to determine if the new wheels and tires would fit on my Boxster. http://www.willtheyfit.com/
2004 Boxster S
eicheldp is offline   Reply With Quote
Old 03-21-2018, 05:32 AM   #6
Cool Wheel Offset question
Folks,
I appreciate all the responses recieved. Will go ahead and pursue this.
Happy Boxstering everyone !
t2
