Old 03-17-2018, 08:18 AM   #1
geraintthomas's Avatar
Bogging while pulling away?
Seem to have another problem. The car bogs when pulling away to the point where it's stalled once or twice if I don't compensate it with revs.
https://youtu.be/aaWPUa50EkY
Recently replaced a very bad air oil separator and thought it may have dirtied the MAF. Cleaned the MAF, still no good. Maybe it's ruined the MAF and needs replacing?
This has only happened since I've had a bad AOS.
Help!
Porsche Boxster S Type 986
Old 03-17-2018, 08:54 AM   #2
Boxster 986
Wolf's Avatar
I want to say it could be a vacuum leak, have you checked your lines to make sure none are cracked?
Wolf is offline   Reply With Quote
Old 03-17-2018, 11:36 AM   #3
Artist, 986S tinkerer
NewArt's Avatar
To properly diagnose a problem like this, a scanner, preferably a Durametric, would be invaluable.
Old 03-17-2018, 11:58 AM   #4
Another possibility, but you should check codes first, is misfires at low to medium throttle. The resistance of the mixture between the points is highest at those throttle settings and the spark will tend to go through cracks in the coils when you are there and then when you give more throttle the mixture resistance decreases and the spark starts jumping between the points. I had a really bad case of this many years ago.
1941 Dodge Luxury Liner Coupe
Old 03-17-2018, 12:05 PM   #5
No codes, after pulling off the performance is fantastic. It's just that initial load on the engine/throttle.
Old 03-17-2018, 01:26 PM   #6
NewArt's Avatar
I've found that a simple way to search for vacuum leaks is to use a can of throttle body cleaner. With the straw you can spray various locations fairly accurately. If the car stumbles or increases in revs, you've found your problem.
Old 03-17-2018, 03:21 PM   #7
There's no vacuum leaks. Have checked lots before changing the AOS, and checked afterwards. The car went back to normal after changing the AOS but has slowly developed this bogging about a week or so after it. If there was a vacuum I'd at least get P0171 or P0174 codes.but it's all fine.
I'm more inclined to think it's a bad MAF as, doing a bit of research, they can go bad after having a bad AOS due to it being contaminated with oil.
Any way to test a MAF?
Old 03-18-2018, 01:22 PM   #8
Have been told by the guys over on Boxa.net that it could be residual oil in the throttle body from the bad AOS, causing the throttle body to not let the correct air flow when it starts to open (because of the oil on the valve), which is why it's poor at low revs (where it's only just opening) and fine afterwards when it's fully open.
Makes sense, will clean it when I get a spare hour.
Old 03-18-2018, 03:59 PM   #9
NewArt's Avatar
Cleaning the TB is pretty easy and you'll see it as soon as it's opened. A fouled TB could possibly cause low rev breathing problems. I don't think MAFs go wonky as often as people think. Often it's a cleaning problem but I'm not sure how a MAF can get contaminated due to a bad AOS. (feel free to correct me here). The air just goes the other way! A MAF could suffer physical damage or maybe die of natural causes, but if it's dirty, a good cleaning should remedy the situation. Good luck, and let us know what you find!
Old 03-18-2018, 04:14 PM   #10
I actually read it on PelicanParts that a MAF can go bad after a bad AOS, but not sure how.
I've cleaned the throttle body about a year ago as part of maintenance, so I'm accustomed to taking it apart. Will take the plenum off too and give that a good scrub.
I've got two brand new lambda sensors waiting to go in. I'm tempted to buy a MAF as well just so that there's all new sensors, clean the TB, and even service the car at the same time. All fresh then.
Old 03-19-2018, 01:26 AM   #11
still plays with cars...
BoxsterSteve's Avatar
Does it bog badly until 2500 or so and then start to pull strongly again?
Mine did this a couple of years back.
Turns out it was a faulty MAF that didn’t set a CEL.
Try unplugging your MAF and see how it runs.
The car will revert to the factory programmed fuel map and throw a CEL, but if it runs like a champ again, you’ve found the problem part and you aren’t replacing things you don’t need to.
Six speed 2000 Boxster S
Old 03-19-2018, 07:34 AM   #12
That's exactly how it feels. Feels like driving a turbo where there's a little bit of lag, and then it really gives it the beans.
I'll try unplugging it later, thank you!
Old 03-19-2018, 10:00 AM   #13
oldskool73's Avatar
Mine also did something like that. replaced the AOS, cleaned the TB & MAF etc... all with no codes... replacing the MAF was the final part of the puzzle that got everything working nicely again.
FWIW, I put in one of the cheapo $30 chinese knockoffs that you can find on ebay as a test, and it was so much better than the 'real' one in there I'm still running it, though not sure how long it'll last.
oldskool73 is offline   Reply With Quote
Old 03-19-2018, 02:24 PM   #14
So... Just took the throttle body and plenum out.
And have a look inside:
Soaked with oil. Cleaned and as good as new.
The throttle body also had a load of gunk. See the black rim?
Much better
Also gave the connecting hose a good clean, and cleaned out the pipes in the intakes.
Car is 100% better thanks everyone who helped!
Old 03-19-2018, 03:31 PM   #15
2003 S, Arctic Silver, M6
paulofto's Avatar
Now your car is very clean INSIDE as well as outside!
