Old 01-23-2018, 06:39 PM   #1
harnishclan's Avatar
SPB Rear Toe Control Arms
Installing Spec Boxster Bilstein PSS suspension and planning on doing rear toe control arms at same time. Question is TunerRS or Tarett? Other than $111.00 price difference, not seeing a difference. Please weigh in!
Brian
Current: SPB Boxster, Macan S, 1984 944
Past: 10 944s, 2 924 Turbo, 911SC, 993, Cayenne, Boxster S, and Cayman S.
Future: 356C
harnishclan is offline   Reply With Quote
Old 01-24-2018, 05:16 AM   #2
Lemming's Avatar
If you plan on running SPB, Tarett is the only aftermarket option allowed.
Tim
1998 986 (3.2L and 6-speed transmission added)
1999 986 (SPB)
1999 986 (parts car)
2001 986 S (parts car)
Lemming is offline   Reply With Quote
Old 01-24-2018, 09:02 AM   #3
steved0x's Avatar
If you are comparing these two:
Porsche 996/997/986/987 Rear Toe Link Control Arms – TuneRS Motorsports
Porsche Rear Toe Control Arm Link, 996, 997, 986 & 987
I don't see any difference. The price difference isn't as much as your thread so I may be looking at the wrong ones. Some include bumpsteer adjustment and so at the outboard end they don't have the standard tie rod end ball joint and pin, like this, and these style are more expensive, and not allowed in Spec Boxster (disclaimer: I don't run SPB):
Toe Control Arm (ea), Motorsport Style
These are what I run, and they include the toe locking plate:
Rennline Rear Toe Control Arm W/Bump Steer Kit-Rennline, Inc.
Old 01-24-2018, 11:25 AM   #4
Actually the rule says:
Rear toe links: stock or Tarett Engineering #996TLNKR, or any similar rear toe link as long as it does not alter suspension geometry beyond being longer and does not function differently than either of the other allowed toe links.
So either is legal, this is a quality vs cost question only.
Tags
spb toe suspension
