Old 10-07-2017, 08:30 AM   #1
Updated Oil Pressure Spring
If I don't want to wait to change the oil pressure spring how much oil will I loose changing the oil pressure spring?
Old 10-07-2017, 11:42 AM   #2
Less than a cup.
Old 10-07-2017, 07:16 PM   #3
Thanks JFP
Old 10-09-2017, 04:13 AM   #4
If you want to upgrade the piston too, will it just fall out once the plug is removed? If you have to extract it how do you do so without marring the walls of the hole?
Jgkram is offline   Reply With Quote
Old 10-09-2017, 06:29 AM   #5
steved0x's Avatar
Mine just fell out, if it doesn't I guess you could poke the old spring back up there and turn it a little to see if that can help dislodge it?
Old 10-09-2017, 08:41 AM   #6
Or use a magnet.
