Old 10-04-2017, 08:02 AM   #1
Center console lid broken
Is it possible to replace the hinged lid on the center console? I have a 2001S and the locking lid broke off. Or do I need to replace the entire center console assembly?
Dave2001S is offline   Reply With Quote
Old 10-04-2017, 01:30 PM   #2
There's a repair kit that has a hinge and some rivets. I had the same issue and got mine from suncoast. It took about 20 minutes to fix.
pussywillow1972 is offline   Reply With Quote
Old 10-04-2017, 01:31 PM   #3
https://www. ************************************************** ** .com /product/99655296001.html
Old 10-04-2017, 03:17 PM   #4
Thanks!
Thanks, I'll check it out
Old 10-12-2017, 10:41 AM   #5
When you post a link, it's best to break it up so that the forum censor doesn't block it.
The lid on my 01 console was broken off at the hinge. I glued it back on, at the hinge, by using Super Glue and baking soda. It's not as strong as new, probably, but most of the plastic on a 17 year old car isn't. If I'm careful it will last. The lock on my console doesn't work anyhow.:ah:
2001 Boxster
2007 Toyota Highlander
Old 10-14-2017, 07:02 PM   #6
Baking Soda??? What does that do??
2003Boxster
1973 Carreras RS tribute
2000 Saab Aero wagon stick
1990 Chevrolet pu pre runner
boxfix is offline   Reply With Quote
Old 10-15-2017, 06:35 AM   #7
It makes the super glue lick. Super glue is not the right glue for this kind of work.
1941 Dodge Luxury Liner Coupe
Old 10-15-2017, 10:00 AM   #8
oldskool73's Avatar
baking soda reacts with the super glue and goes much harder much quicker, it's a pretty cool reaction...
https://www.youtube.com/watch?v=slCMkvEfK_U
may as well just get the kit though, it's vastly overpriced for a bit of metal and a couple of rivets but it's quick and easy to do and won't break again for the life of the car.
oldskool73 is offline   Reply With Quote
Old 10-17-2017, 05:40 PM   #9
Update, I ordered the kit and gave it a try. Its excellent, fit is perfect, cost is minimal, and the install takes maybe an hour at most. I augmented the two screws that hold the new hinge in place with a bit of epoxy. Thanks for the recommendation
