Old 09-27-2017, 07:24 AM   #1
JT1
radiator fans
Hello,
Think I posted this in the wrong forum so will try again.
Does anyone know the diameter of the rotor on these fans as I
would like to try a non oem one
JT1 is offline   Reply With Quote
Old 09-27-2017, 07:41 AM   #2
steved0x's Avatar
Let me see if I can get you a part number, Pulse racing in Jax runs Spal radiator fans on their builds (Mostly Caymans I think) and they would give me some part numbers, I just never got around to asking. I'll try and do it today...
Old 09-27-2017, 09:38 AM   #3
78F350's Avatar
Are you asking what the diameter of the rotor on the radiator fans is? It looks like 10-3/4" on the inside. You should probably just remove your bad one now for examining and measuring exactly yourself if it is not working anyway.
Old 09-27-2017, 02:48 PM   #4
Are you 100% sure fan is bad?
Hi/low ballast resistors are known to go.
You may have been missing low or hi for some time but didn't notice until both are now gone.
I'd test the fan directly first and then resistor. Replace only what you need.
Good luck
"Cool Prius!"
- Nobody
Old 09-28-2017, 12:48 AM   #5
JT1
Thanks all for your replies - I have checked it and swapped relays etc, pretty sure its gone . Will keep you posted !
