Old 09-17-2017, 09:38 PM   #1
Replace window regulator motor or not?
Based on my search, it looks like my regulator on my drivers door is shot. It makes a sound like a rock is scratching the glass, which im guessing is a piece of plastic or something. So my question is this, should i replace the regulator and motor? Or is it possible to save the motor? Thanks for any input.
Joe
Snipershot is offline   Reply With Quote
Old 09-18-2017, 05:48 AM   #2
JamesBound's Avatar
The motor might be ok. Try looking what caused the issue.
JamesBound is offline   Reply With Quote
Old 09-18-2017, 05:55 AM   #3
Bald Eagle's Avatar
Disclaimer: I'm not a wrench, a Boxster owning friend replaced the regulator when I had a scratching noise. We didn't do anything about the motor as it was working fine and that solved the problem. Motor still works perfectly and the noise is gone.
Larry (The Bald Eagle)
Old 09-18-2017, 06:42 AM   #4
78F350's Avatar
Save the motor. They last a lot longer than the regulators. I have replaced about a half dozen regulators and never had to replace a motor.
In case you have not seen the Pelican Parts tech article:
Porsche Boxster Window Regulator Replacement / Window Switch Replacement / Window Motor Replacement - 986 / 987 (1997-08) - Pelican Parts Technical Article
Be sure to pay attention to the last step, Window Adjustment.
Old 09-18-2017, 08:18 AM   #5
Multi-Boxer Driver
Deserion's Avatar
The motors generally aren't the failure point on our cars, but the cable tension on the regulators sure is!
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 09-18-2017, 12:48 PM   #6
Porsche9's Avatar
+4 on it being the regulator.
03 Carrera
89 Carrera 4
89 944 S2
78 911SC
Old 09-18-2017, 06:06 PM   #7
You may be able to save it. Underneath the door, there are four rubber plugs remove the plugs and squirt oil onto the white pulleys while somebody operates the window. If the sound goes away, then you are good.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 09-19-2017, 07:09 PM   #8
Thanks fellas, all the info is much appreciated!
Joe
Old 09-22-2017, 08:49 AM   #9
geraintthomas's Avatar
It's just the cable (i.e. the regulator). Same happened to me. If it's grinding, the motor is working and you're hearing the broken cable scratch its way around the door.
I bought an eBay one for £80, replaced it myself and it's still going strong 2 years later. It's not a hard job, just a little fiddly.
Porsche Boxster S Type 986
Old 09-22-2017, 12:22 PM   #10
I had my driver side regulator replaced and now the window does not drop when putting the top down. The passenger one works properly. What is the trick here to make it drop so it does not interfere with the top operation?
FoxRvrBox is offline   Reply With Quote
