Old 08-08-2017, 08:01 PM   #1
Missing at low RPMs
My car started missing at idle, just pulling out or at very low RPM while driving. As soon as I get above 3k it smooths out and runs great. Come to a stop and while idling it huffs and puffs. This happens in any gear if I am lugging around, idling, or just trying to pull off smoothly from a stop light or whatever. Any ideas?
2000 Black 996 Aero, 2001 Forest Green Boxster S, 94 Midnight Blue 968 Cab, 1980 Pongee Beige 911SC Weissach Edition, 2004 BMW R1200CLC
ymkmkrz is offline   Reply With Quote
Old 08-08-2017, 08:26 PM   #2
loose coil pack wire? bad plug? codes?
Old 08-08-2017, 08:31 PM   #3
No codes as yet, but I suspect there will be some soon. I can keep it running smoothly by keeping my foot in the throttle a bit, even when parking. But if I don't, it will miss badly. I haven't taken the cover off yet. It just started this morning and I wasn't really sure what to check. The coil pack or wire could be a good place to start though. Perhaps with quicker spark it works normally. Tnx
Old 08-08-2017, 10:03 PM   #4
911monty's Avatar
Vacuum leak. At idle a leak has a greater effect than at higher airflow rates. Lean condition causes misfire.
Old 08-09-2017, 07:47 AM   #5
Thanks Monty! That makes perfect sense
