Old 07-19-2006, 02:51 PM   #1
Klackiting in my front and rear suspension
does this mean my shocks/struts are in need of a replacement...sorta sounds like a broken shock slapping the suspension when i go over cracks in the street at normal speeds like 25-45 mph
Old 07-19-2006, 02:52 PM   #2
bmussatti
Posts: n/a
What is your mileage?
Could be a CV joint too.
Old 07-19-2006, 04:46 PM   #3
I have 94k....ok cv boot. but is too much of a coincedence that i hear sorta the same sound front and rear of the car? Thanks for helping me.
Old 07-23-2006, 08:45 AM   #4
Thumper's Avatar
Check your swaybar links.
Thumper is offline   Reply With Quote
Old 07-25-2006, 10:48 AM   #5
oh i just created a new thread for this issue, but thanks, i will check that out.
Old 07-25-2006, 12:15 PM   #6
i had that issue on my car; turned out to be the bushing on a diagnoal control arm (can't buy just the bushings). i replaced the control arm. i have since found out that there are bearing cartridges available for the boxster; these should last longer. can't remember where i saw them (maybe the racer's group, elephant racing, or performance products)..
insite
'99 Boxster
3.4L Conversion
Old 07-27-2006, 04:24 PM   #7
If i had the car up on stands or a lift, how would i be able to tell if are those bushing? would i be able to shake the wheel and notice the control arm moving slightly where the bushing is?
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
